Bottom spray arm replacement
Brand:Kenmore
Model Number:665.14573N612
Main Symptom:need to replace bottom spray arm
What happens & when:part page says to also replace upper washer arm support.Is this necessary?
No, you generally do not need to replace the upper spray arm support when replacing the lower spray arm on your Kenmore dishwasher, model 665.14573N612.
The lower spray arm and upper spray arm support are separate components. If you’re replacing the lower spray arm because it’s cracked, damaged, or no longer spinning properly, you should be able to replace just that part.
However, I would recommend checking the following before ordering:
  • Lower spray arm: Check for cracks, clogged spray holes, or damage around the mounting area.
  • Upper spray arm support: Check for cracks, worn connections, or water leaks. If it’s in good condition, there’s usually no reason to replace it.
Important clarification: I checked the actual parts listing, and it specifically states that if this is your first time replacing the lower spray arm, you also need wash arm support W11573369 (Whirlpool W11573369 Dishwasher Upper Wash Arm Support | Genuine OEM Part). This is because the replacement spray arm uses an updated mounting arrangement.
Appliance Parts Pros
The correct replacement lower spray arm is WPW10491331 (Whirlpool WPW10491331 Dishwasher Spray Arm | Genuine OEM Part).
So, if you’re installing the updated spray arm for the first time, I recommend ordering both parts. You do not need to replace the entire upper spray arm assembly.
You can view both parts in the Kenmore 665.14573N612 parts diagram
