Bottom freezer has ice on bottem under pull out drawer
I recently replaced the freezer gasket now I am noticing ice in the bottom of the freezer under the pull out drawer, I have cleaned the drain tube with a turkey baster and baking soda but it is still happening. Any ideas what to check next?
Did the water go all the way through when you cleaned the drain?
yes, the water went all the through, I even took the bottom half off of the drain in the back of the refrigerator to make sure that it is dripping. Water did come through when I squirted water through it.
