Both oven elements won't heat
I have a Norge stove about 10-12 years old,both oven elements won"t heat up. The clock is off, the fuses are fine, the element doesn’t appear burnt,cracked,or bubbled. In fact I have changed both elements, but get the same results. The top elements are good. What’s next:confused:
Al,
First thing I would do is:
Check and make sure both breakers are reset,and locked in position.
Remove the back panel of the range, and check for broken, burnt wires to the element(s).
Access the control panel, and do the same check, there.
I can’t find that model number in any of our tech data or parts diagrams, but I’m thinking,hoping that you’ve lost one of the voltage supply lines to the control panel,and thats why the oven won’t heat and the clock is dead.
Would, could you varify the model number again, please.
Hi Joe thanks for the instructions for trouble shooting my oven. I’m going to attempt these tips on my days off. Also I took another look at the model number and this is the new configuration BNEW3G8 CX…I think. The Bs look like 8s.:slight_smile:
                                        Thanks Al
[quote=Al M;298065]Hi Joe thanks for the instructions for trouble shooting my oven. I’m going to attempt these tips on my days off. Also I took another look at the model number and this is the new configuration BNEW3G8 CX…I think. The Bs look like 8s.:slight_smile:
Thanks Al[/quote]
Al,
We’re still having a problem with that model number.
In the mean time, go ahead and do those checks, and let us know what you find.
I’ll try and find some information on that range, so we can get you on the track, if it’s more than a damaged wire or breaker.
Keep in touch,
:cool: :cool: :cool:
