Bosch wont shut off
When started, the Bosch SHU6800 starts at 13 minutes and never does fully reset to run at maximum alloted time. I have shut off the power, changed cycles and tried a number of different things to get it to start at the beginning of the cycle. When it reaches 1 minute it just keeps running and never shuts off until shut it off manually. When shut off manually, there is stull water in the bottom of the dishwasher. What can I do to resolve this problem?
Charlie,
Most likely the problem is a bad control module. The instructions are attached top the reply.
How to replace control module.pdf (54.6 KB)
