Brand:Bosch
Model Number:shs5av52uc/22
Main Symptom:won’t drain
What happens & when:cycle starts, adds water, starts to drain then stops
Parts or tests already tried:cleaned filters, replaced drain pump, control panel, and water inlet valve
Photos / video link: none
There is standing water inside the dishwasher. If I remove the water manually I can restart the machine. It fill and starts to drain but not completely. The water gets about two feet away from the sink and stops. The machine sits for a few minutes I hear a few clicks, it shuts down andThe sanitize button is blinking. This model has no display for error codes. Also, the soap dispenser never opens.
