Brand: Bosch Model Number: WFMC5301UC/15 Main Symptom: Error code E.13, soapy clothes What happens & when:
I have a Bosch WFMC5301UC/15 front load washer. Symptoms/data are:
-Machine is about 15 years old
-In the last few months, we frequently get error code E.13 which I understand means “Drain pump time exceeded”
-Clothes are still very soapy even though we have drastically reduced the amount of soap we are using
-We can run a 2 hour “Soak” cycle, and while it is running, I can see a fair amount of soap bubbles in the water as I look through the front window
-I can manually initiate the spin cycle (e.g. P:04) and the drain pump operates as expected
-I have opened the access plug that goes to the pump and there is no debris present. I can spin the pump impeller by hand and don’t feel any restriction. The impeller does not have any wobble or play as far as I can tell.
-The drain hose from the back of the washer to our sink is not blocked or kinked.
-The machine has gotten noisy. Can’t tell if it is noise from the pump, or the drum motor/belt.
I hate to throw parts at something when there is no clear cut diagnosis. I’m hoping to get advice from this forum on the most likely root causes. Thanks for any help
Based on everything you’ve checked so far, I wouldn’t replace the drain pump just yet. You’ve already done some good troubleshooting, and I think there are a couple of things worth checking before spending money on parts.
On your Bosch WFMC5301UC/15, the E:13 error means the washer is taking too long to drain. However, that doesn’t necessarily mean the drain pump has failed. Excessive suds can also interfere with draining and spinning, so the soapy clothes and E:13 error may be related.
Here’s how I would narrow it down.
1. Check the actual drain flow. Since you’ve confirmed the pump runs during the P:04 test, I’d start by watching how much water it moves. Run a drain cycle with some water in the tub and observe the discharge into your sink. You should see a strong, steady stream of water. If the flow is weak or intermittent, there may still be a restriction or the pump may be getting weak.
2. Check the hose between the tub and drain pump. You’ve already inspected the pump filter and external drain hose, but there’s also a large rubber hose connecting the bottom of the tub to the pump. Small clothing items, lint, and other debris can collect there and restrict water flow. Unplug the washer, drain any remaining water, and inspect that hose for obstructions.
3. Rule out detergent buildup and excessive suds. This is particularly important because you’re still seeing bubbles after reducing the detergent. Over time, detergent residue can accumulate inside the outer tub and hoses. Try running an empty hot-water cycle without adding any detergent. If you still see a lot of suds, there’s likely detergent residue remaining in the machine. You may need to repeat the rinse or cleaning process several times to flush it out.
4. Identify where the noise is coming from. Since you’ve mentioned the washer has gotten noisy, I’d like to determine whether the noise happens during draining or spinning.
If the noise occurs primarily while the pump is running, I’d suspect a worn drain pump or something contacting the impeller.
If the noise gets louder as the drum speeds up, I’d be more concerned about the drum bearings or another mechanical issue.
You can also rotate the empty drum by hand with the washer unplugged. Listen for grinding or rumbling and check for excessive movement of the inner drum relative to the outer tub.
5. Consider a weakening drain pump. Even though the impeller turns freely by hand and the pump operates during diagnostics, that doesn’t completely rule out a failing pump. A pump can run but still have trouble moving water efficiently, particularly when handling a full tub of water.
Before replacing it, I’d want to confirm that the drain flow is poor and that there are no restrictions in the hoses.
My recommendation: Start with the drain-flow test and the empty hot-water cycle without detergent. Those two tests should help determine whether you’re dealing with a drainage problem, excessive suds, or possibly both.
I have two questions that would help narrow this down further:
When the washer gets noisy, is it during the drain portion of the cycle or when the drum is spinning at high speed?
When you run P:04, does the washer pump the water out quickly with a strong stream, or does it seem to drain slowly?
Those answers should help us decide whether the drain pump deserves further testing or whether we should focus on something else before ordering parts.
Thank you very much for the detailed reply. Here is what I have done:
Added a bucket of water to the drum and ran the P:04 test. There is a strong, steady stream of water
Regarding the tub to pump hose: I can see it when I peer in through the access port on front, but I don’t see any way to inspect what is in the hose without removing either the front or the back of the washer. I’m holding off on this test for now.
We ran several hot water only cycles, and the amount of suds seems to have gone down.
I “think” the noise only happens when the pump is running. I have watched/listened when the drum is spinning quickly with no pump, and I don’t hear the noise. I can’t hear/feel anything funny when I rotate the drum by hand
I am going to order the Affresh washer cleaner tablets as well.
Thanks for the update! Those test results are actually very helpful, and I think we’re getting closer to finding the problem with your Bosch WFMC5301UC/15 washer.
The good news is that I’m much less concerned about the drum bearings or drive motor now. Since the noise seems to happen only when the drain pump runs, I’d concentrate on the drain system.
Here’s what your results tell us:
1. Strong, steady water flow during P:04: That’s encouraging. It tells us the pump can move water and that the drain line isn’t completely blocked. However, it doesn’t completely rule out a partially restricted tub-to-pump hose or a pump that’s beginning to wear out.
2. Suds are decreasing: That’s another good sign. Excess detergent buildup can cause draining problems and contribute to the E:13 error. I’d continue running a few rinse cycles without detergent until the suds disappear.
3. Noise only when the pump runs: This is our biggest clue. A worn pump motor, damaged impeller, or small object bouncing around inside the pump housing could explain the noise.
Here’s what I’d recommend next.
Before taking the washer apart to inspect the tub-to-pump hose, I’d run one more test.
Add a couple of gallons of clean water to the drum and run P:04 again. This time, listen carefully to the pump.
If you hear grinding, rattling, or growling while it’s draining, I’d strongly suspect the drain pump.
If the pump sounds normal and empties the water quickly, I’d hold off on replacing it.
If the water flow starts strong but becomes weak or inconsistent, we may still have a partial restriction or something interfering with the impeller.
Unplug the washer before opening the pump filter or inspecting anything inside.
One other thing I’d suggest is running a normal wash cycle with a small load and very little HE detergent once the suds have cleared. That will tell us whether the E:13 error is still occurring under normal conditions. Bosch also identifies excessive suds as a possible cause of this error.
Bosch Home
+1
My recommendation: Don’t purchase a pump or disassemble the washer just yet. If the noise continues after the suds are gone, the drain pump would be my leading suspect.
One question: When you hear the noise, is it a grinding or rattling sound, or more of a loud humming or buzzing? That distinction will help us determine whether the pump is wearing out or something may be caught inside it.
I dumped several gallons of water in the tub and ran the P:04 drain cycle. I’m attaching a link to the video I took (here), rather than me trying to describe the noise. It seems that the flow was strong and suds free. The rhythmic noise doesn’t start until most of the water has been emptied from the tub. Does that seem like a pump noise? Again, thanks much for all your help.
Thanks for the update! That’s actually encouraging news.
Based on what you’re describing, the rhythmic noise sounds like normal drain pump operation once most of the water has been removed from the tub. As the water level drops, the pump starts pulling in some air along with the remaining water. That can produce a rhythmic rattling or pulsing sound.
The fact that you have a strong, steady stream of water with no visible suds is a good sign. It tells us the pump is moving water effectively, and there doesn’t appear to be a major restriction in the drain line.
At this point, I wouldn’t replace the drain pump. Your test makes a failing pump less likely.
I’d recommend running another empty hot-water cycle without detergent to continue flushing out any remaining soap buildup. Excessive suds can contribute to the E:13 drain-time error on these Bosch washers.
ManualOwl
+1
After that, try a normal wash cycle and see whether the E:13 code returns.
One question: When the washer finishes draining during a normal cycle, does it continue into the spin cycle, or does it stop and display E:13?
That will help us determine whether we need to investigate the water-level sensing system next.
