Washing machine won’t drain. We have removed the drainage pipe in the rear several times to check for a blockage, but the drain is clear. Is there another location where the machine can be blocked?
have you checked the drain hose under sink , stick a screw driver down where hose connects to .other than that it could be a pump issue , remove front door panel +bottom panel ,has torque screws to easier acess to pump
