Bosch washer "door open?" error
My “door open?” error is displayed and machine will not start. This seems to be a common problem with this model and replacing the door lock switch does not help. Any ideas?
If you look through this Forum you will see very few Bosch posts, and even less answered because it is just not a brand we often work. See if you can locate anothe Forum that will be able to help.
Good luck.
