I have a Slimline Bosch dishwasher that will not empty. I have cleaned the bottom of the dishwasher out and removed the cover for the impeller. I have removed the discharge pipe to see if there is any debris in there and cleared that out too. It will still not empty. I reckon it could either be a water level sensor or the pump (any other ideas would be welcomed). I have taken the unit apart but can’t seem to get the the pump in the base of the unit and I don’t know if there is a water level sensor (or where to find it) Could anyone advise on how to remove the base of the unit so I can get to the pump and let me know if/where the water level sensor is? Thanks in advance
Looks like this is a UK model and we do not have any technical data for non American models. You can find the instructions for American models attached to the reply. Hopefully it will help.
How to remove the base from the tank.pdf (190.1 KB)
