Bosch SHX68T55UC/01 leak causing E15 error code
Brand: Bosch
Model Number: SHX68T55UC/01
Main Symptom: Leaking
What happens & when: With 18+ minutes left in cycle (maybe as early as 0:35) , water begins dripping from the sump assembly. You can see the water in the red circle below. Another photo appears to show too much water in the bottom of the unit.
The time shown on the unit when you start it is 2:20, but it seems to take 2:45. I attempted to determine when the time shift occurs, and it was before 1:12.
The amount of water varies. Sometimes, there doesn’t appear to be any, and at other times, there is a lot.
Error Code (if any): E15 will occur if water is not removed from bottom case
Parts or tests already tried: Tests have been limited to monitoring the unit in use to determine when and where the leak is occurring.
That’s going to be an issue with the sump assembly 00752078, could be the seal or the sump itself but they only come together anyways so you’d be replacing both regardless.
