Bosch SHU8802 Stuck Draining
My Bosch SHU8802UC/UC12 is stuck in the draining part of the cycle. The dishwasher continues to run even when the door is opened. It will power off if I shut it off via the power button. I have tried tripping the breaker to the dishwasher and after powering back on it is still in the same endless draining cycle. I have tried dumping some water in the tub and the water does drain very quickly so it does not appear to be clogged. Filters are clean. I appreciate any sugestions. I do have a multimeter to do continuity tests, I just don’t know where to begin or what the results should be.
Thank you!
Ryan
Hi Ryan,
Remove the toe panel and check for water in the base. Check the door latch switch (instructions attached).
Here are the breakdown diagrams and Replacement parts for BOSCH SHU8802 UC/12 (FD 8105-) | AppliancePartsPros.com
Door latch in integrated models 1.pdf (410.7 KB)
Door latch in integrated models 2.pdf (388.0 KB)
Gene,
Thank you for the help, I sure appreciate it. I checked for water in the base - it’s completely dry, no signs of water at all. This dishwater has never needed service / never been opened so I don’t think the latch switch is miss-wired. Could a bad latch switch cause this?
Thanks,
Ryan
If the dishwasher is working with the door open then there is definitely something wrong with the door switch. The instructions attached to the previous reply are not only about miss wired switch.
You also have to remove the dishwasher from the cabinet and check the water level switch assembly (on the left side).
I just checked continuity across the terminals on the latch switch. The latch switch has 3 terminals. I will call them (from left to right) 1,2,3. When the door is opened continuity between:
1-2 = opened
2-3 = closed
When the door is closed continuity between:
1-2 = opened
2-3 = opened
This seems wrong. What should be happening here?
Thank you Gene.
Ryan
If you look at the picture of the switch
you’ll see the three terminals. The very bottom terminal is Common, the middle terminal is Normally Open and the upper terminal is Normally Closed.
With the door closed your meter should read the open circuit between the Com. and NC terminals, and the closed circuit between the Com. and the NO terminals.
I do not have the wiring diagram for this model, but I believe there suppose to be two wires connected to the switch, one to the Com. terminal and another one to the NO terminal.
According to the documentation you provided in your last reply, the switch tests fine. So if the latch switch is working properly, would a problem with the float you spoke of earlier cause this? It just seems odd about it running with the door opened. The controls do light up by the way. Think it could be a bad control module? When I unplug the wire harness that has three white wires and an orange color on the connector, the motor does stop. Does this help at all?
Check the door latch alignment as instructed in the attached file (1).
Latch alignment is definitly correct. I have even tested continuity across the latch switch with the door open and closed - the switch is tripping.
Ryan
Well, I called a Bosch professional to come take a look at my problem. It turns out the only thing wrong was the float was stuck. He removed the toe panel and wiggled the float up and down a couple times. It’s working great again.
Gene, thank you for all the help and suggestions you gave me -and the rest of this forum for that matter- I really appreciate it.
Ryan
Ryan,
You are welcome. I’m glad it was that simple.
