Bosch SHU53Asked by Kd for Model
Bosch SHU5315UCAsked by Kd for Model
Hi KD. To reset the control module AP2802870, you will put the dishwasher into the cancel/drain mode and let it complete the cycle. When you installed the new control remove the jumper from the original front lower right hand # 1 board male port. Starting from the extreme lower rt.corner, there is a 6-terminal connector with a jumper wire looping # 5 and # 6 terminals. (counting from the right to the left). Use this on your new board. Then reset the controls. Thank You. Answered by AppliancePartsPros.com
[/COLOR]
[/LEFT]
