Bosch SHU3326UC problems
We have had a few problems crop up suddenly on our DW. Original problem of not draining was dealt with after 3 attempts and then the recall to replace the main circuit board was also done.
Since the circuit board and the pressure chamber were replaced the soap dispenser will not open. Any chance that the connectors to the circuit board were not fittted properly and causing this condition? The reason I ask is that the repair man that installed the circuit boad & pressure chamber did not seem to sure of himself, and also did not pay attention to little details such as checking for leaks after repair and fitting the washer back into it’s space properly.
Thanx in advance for your help.
Paul:confused:
Just thought I’d toss this back up in the que to see if anyone has a suggestion.
Thanx.
