BOSCH
shem63w55n/13
E15
Panel shows code E15. On/off button does not turn the unit off. Tried power cycling the unit - no effect. Pulled the unit out. There was no water under the unit, and when tipped to 45 degrees there was no water in the pan, so, no leaks below the unit. Any thoughts or suggestions?
If there is no water in the base, check the connections at the float switch housing 00751391, this housing has the switch built into it. If those connections look good check the continuity of the float switch, should read closed.
Hi all,
Wonder if the base float or switch just got stuck up in the tripped position?
jeff sr.
If it is in the up position, it thinks it is full of water and will not add more water.
