My Bosch oven does not heat up. The stove top and the broiler are fine. I suspect the igniter. I have the part, but don’t know how to access the wires to install it. I had looked around the web to find general instructions on installing an igniter, and it seemed easy.
I took off the bottom of the oven to access the igniter, but the wires go behind the frame so I cannot access it. I have included a pic. Do I have to go through the back panel to access the igniter wires. Or, more generally, how do I access the igniter wires.
Thanks for the help!
There is no way I can see to remove the aluminum frame at the bottom in the pic.
