Bosch Gas Oven Questions
[SIZE=2]Hello. I, too, have a Bosch oven that has stopped working. It is a free-standing gas range model HGS255UC, about 4 years old. The cooktop and broiler are fine and the display looks like all is normal but the oven burner never lights. I am assuming it is the igniter, but before I replace it I have a couple of questions. I opened up the back but did not find any breakers to re-set. Are there any I am missing? Also, there is a main circuit board in the back with a red LED that is flashing (about one second on and one second off). It is only labeled as “LED 1.” Does this signify something??? The igniter itself looks like your P/N AP4012072 except that the two wires terminate in individual spade connectors rather than a single connector. Thank you for any assistance. [/SIZE]
[SIZE=2]- John[/SIZE]
John,
Unplug the igniter wires and check for 120 VAC between these wires wile the control calls for Bake. If there is proper voltage then the igniter is 100% bad.
  • The part number for the OEM igniter is AP3674290
