Bosch DW refills after cycle
Hi - I have a Bosch dishwasher that runs and drains normally. The problem is that after the cycle finishes (and drains completely), water slowly refills in the bottom of the tub. It will overflow if left overnight. If the dishwasher is left on, the pump will kick in every now and then and keep it from overflowing. But I would like to fix it if I can.
Looking at the parts breakdown diagrams on the site, I see something called a “water inlet system,” a $77 part. Is this what I need? Will I have to pull out the dishwasher to fix it or can it be fixed just through the kickplate? Or am I crazy to attempt this myself…
[quote=VinceInSeattle;157967]Hi - I have a Bosch dishwasher that runs and drains normally. The problem is that after the cycle finishes (and drains completely), water slowly refills in the bottom of the tub. It will overflow if left overnight. If the dishwasher is left on, the pump will kick in every now and then and keep it from overflowing. But I would like to fix it if I can.
Looking at the parts breakdown diagrams on the site, I see something called a “water inlet system,” a $77 part. Is this what I need? Will I have to pull out the dishwasher to fix it or can it be fixed just through the kickplate? Or am I crazy to attempt this myself…[/quote]
Finally got around to installing this part, and the dishwasher still slowly refills after the cycle is over! Anyone have any ideas?
