BOSCH DW Does not run thru cycles
Power is on to the unit and light comes on when starting the DW. DW will not fill and will not advance thru cycles. Motor runs like usual on start up but no water inlet or advance on any of the three settings.
check to see if there is any water in white basin beneath stainless steel tank ? especially to the left of the water inlet valve ?
yes often these water valves leak .and all you will hear is drain pumping ,
