Bosch DW does not fill or drain properly
I have cheched the drain hose to the disposal and made sure it has the loop required. The wash motor starts but stops after a small amt of water enters. The I force the water to drain with the two cancel drail buttons. I can hear the motor start but it wont drain. I manually drain it with a small shop vac. What do i do now? I down loaded the trouble shooting manual posted by someone earlier. Do I need a New drain pump. Clean it? New water valveterminal or level switch? Circulation pump? Flow switch? HELP PLEASE!
Hi Carol,
Perform the troubleshooting as described in the troubleshooting manual for one of our previous posts: http://forum.appliancepartspros.com/dishwasher-repair/7123-bosch-dishwasher-troubleshoot-manual.html
Here are the break down diagrams for the Bosch dishwasher Model SHU9915 UC/12 (FD 8003-)
[QUOTE=Gene;35895]Hi Carol,
Gene.[/QUOTE]
would the problem be in the circulation sump pump? Is it hard to open and take apart and do I have to be careful of anything special? Could the hose be clogged at the end where it connects to the pump not at the disposal end?
Gene the manual wont load on my computer?
I cant pull it out. do i have to disconnect something below before i can pull it out? I unpluged it. I feel stupid.
Carol,
Unfortunately I do not have enough time to type in the troubleshooting guide. I just checked the link (bosch dishwasher troubleshoot manual) and it works.
[QUOTE=carol kittelson;35858]I have cheched the drain hose to the disposal and made sure it has the loop required. The wash motor starts but stops after a small amt of water enters. The I force the water to drain with the two cancel drail buttons. I can hear the motor start but it wont drain. I manually drain it with a small shop vac. What do i do now? I down loaded the trouble shooting manual posted by someone earlier. Do I need a New drain pump. Clean it? New water valveterminal or level switch? Circulation pump? Flow switch? HELP PLEASE![/QUOTE]
Cant anyone HELP?
