Bosch dryer wont start
Everything was working,power,gas…but now the dryer wont start. There are no codes displayed, lint filter is clean,sensors are clean(used white vinegar) but still nothing. It sounds like 2 clicks coming from the dial area when i push start. Can You please help??
Hi Racks
If you look on this Forum you will see very few Bosch questions answer, I think because few of us (certainly myself) have experience on these machines.
I suggest you try a different Forum and see if you have better luck.
Good luck, sorry we could not have been of much help
I have exact same problem.. seems to be the motor
the problem was a faulty broken belt switch. Open dryer from the back, switch is on bottom left side. It is white and has a black arm with a spring on it. It is a safety feature that, in the event the belt breaks, the dryer will shut off. My belt wasnt broke, so i pushed the arm to the right, tried the dryer and it worked fine!!!
[quote=sidfink43;110645]Hi Racks
Good luck, sorry we could not have been of much help[/quote]
The problem was a faulty belt sensor switch. Bosch was VERY un-helpful.
Glad you got it fixed and thanks for the update. I am sure that will help others who post on the Forum
Bosch is not known for customer friendly attitude, another reason why their sales are not very high in this country.
