I have had my bosch dryer for just over a year (warranty not applicable) and for the past 3 weeks the dryer turns off with out finishing the cycle and I get an error message E0:1 and the lint filter light starts blinking. I have cleaned out the filter several times and nothing works. It has gotten so bad that I can not dry my clothes and it all smells. Any help would be appreciated.
Hello,
The E:01 is a code that is generated when the sensor near the lint filter gets too hot. This is usually caused by bad air flow.
Try running the unit without the vent hose attached. If the problem goes away the problem is in the ducting. You may need to have it cleaned out. I’ve also seen this if the lint filter is clogged due to the use of dryer sheets or fabric softener. You can try to clean the filter with Windex if this is a possibility.
If neither one of this suggestions resolves the issue there may be a problem with the sensor, Bosch part number 154166, or there may be heat escaping somewhere within the dryer.
First poster had it right. It’s in the duct work and probably outside where the duct work exits.
The trap door on the dryer vent may be full of lint and not letting the hot air pass. This might be esp true if the vent has a rodent barrier. The lint has collected on the barrier and is blocking the airflow.
After much frustration over the constant Lint Filter Error that stops the drying cycle before it’s done, and having the technicians come out and tell me it’s a common problem, clean out my filter (like I didn’t try that before) and leave without fixing it, I took matters into my own hands.
It’s a simple fix. Have you ever noticed that they have provided the worlds smallest filter mesh. I don’t know how anything could ever get through that thing including air. FIND A THUMB TACK AND POKE HOLES IN YOUR FILTER ABOUT EVERY CENTIMETER. SHOULD BE ABOUT 200 HOLES TOTAL. NOW AIR GETS THROUGH AND DOES NOT TRIGGER THE SENSOR. PROBLEM SOLVED.
[quote=[LEFT][COLOR=red][FONT=serif]mrdeeds[/FONT][/COLOR][/left];51350]After much frustration over the constant Lint Filter Error that stops the drying cycle before it’s done, and having the technicians come out and tell me it’s a common problem, clean out my filter (like I didn’t try that before) and leave without fixing it, I took matters into my own hands.
It’s a simple fix. Have you ever noticed that they have provided the worlds smallest filter mesh. I don’t know how anything could ever get through that thing including air. FIND A THUMB TACK AND POKE HOLES IN YOUR FILTER ABOUT EVERY CENTIMETER. SHOULD BE ABOUT 200 HOLES TOTAL. NOW AIR GETS THROUGH AND DOES NOT TRIGGER THE SENSOR. PROBLEM SOLVED.[/quote]
If the lint light is coming on without an error code it’s not due to the lint screen being blocked up. The most common cause of this is the door switch opening up when after the dryer heats up. When this happens the unit feels the door has opened and turns on the lock light as a reminder to clean the lint screen. You may not believe me, so you can test this by starting your dryer then opening the door. You’ll notice that the lint light will come on.
A clogged lint screen will cause the E:01 code along with the lint light.
Sink. You can clean the lint filter under the water by scrubbing it with the brush. Not hard to do. Old Frigidaire dryers used to have the same fine mess. Cause poor heating. E1 is set off by imprper air circulation. Try this before poking holes in the lint filter. That may cause more prblems down the road. Leaving lint in the vents.
[quote=Servicer;51414]If the lint light is coming on without an error code it’s not due to the lint screen being blocked up. The most common cause of this is the door switch opening up when after the dryer heats up. When this happens the unit feels the door has opened and turns on the lock light as a reminder to clean the lint screen. You may not believe me, so you can test this by starting your dryer then opening the door. You’ll notice that the lint light will come on.
A clogged lint screen will cause the E:01 code along with the lint light.[/quote]
Hello,
In the scenario above, what would be the solution for the problem? How do you fix it? Thank you!
I’ve owned this dryer for years and know that when the “Lint Filter” light lights - and the dryer stops, you would think the solution is with the lint filter. It’s not: I have found that the cause of the problem is an accummulation of lint on the wires in the heater chamber in the rear of the dryer. Unfortunately, lint seeps into that chamber and slowly covers the wires which, unfortunately, triggers the bogus “lint filter” light.
Get a compressor or shop vac and clean off those filaments and guess what? lint filter light doesn’t come on no parts needed.
This is simply a correction to the model number in the previous post about the erroneous “lint filter” light problem afflicting these over-priced Bosch products. My product’s numer is 3510 but I have seen this problem in newer models of this dryer. Shame on Bosch.
[QUOTE=ldonts1;14772]I have had my bosch dryer for just over a year (warranty not applicable) and for the past 3 weeks the dryer turns off with out finishing the cycle and I get an error message E0:1 and the lint filter light starts blinking. I have cleaned out the filter several times and nothing works. It has gotten so bad that I can not dry my clothes and it all smells. Any help would be appreciated.
Lana[/QUOTE]
Just had mine repaired..easy fix. I got the tech to tell me what he did.
He reset the computer on the dryer.
Unplug for 10 sec
Plug in for 2-3 sec
Unplug for 10 sec
Plug back in and the computer is reset.
He said that if you open the door while the unit is running then it will throw off everything. Made sense since I had done that several times.
Good luck.
Working and it only cost me $100 which I gladly pass on to you!
[quote=JDC33020;663591]Just had mine repaired..easy fix. I got the tech to tell me what he did.
Unplug for 10 sec
Plug in for 2-3 sec
Unplug for 10 sec
Good luck.
Working and it only cost me $100 which I gladly pass on to you![/quote]
Thank you very much for sharing this solution. A couple of clarifications:
Was your dryer getting the “E0:1” error or would it just not finish the cycle with “lint filter” light blinking?
The unplug-plug-unplug solution… is it done with the cycle selector off?
My wife has a Bosch Premium dryer that had drying problems. The lint filter would get cleaned but the machine still did not operate correctly, as you explained above. Her machine was made in 2005 and the lint screen, the plastic slotted unit in front of the lint filter was the problem. It gets clogged up with hair/lint that never makes it to the filter. I tried a shop vac to vacuum it but the problem was still there. Get a pistol cleaning kit for a 22 cal gun. Pull the lint filter out & then take the pistol rod and insert it from the drum side into each slot and pull out the tons of lint. Pull the lint off the rod when done and take a flame to burn the rest off as the rod is a brass brush with small wires on it.
Ok, I had the same issues. THe repair man first reset the dryer, that did not work. He finally came back and replace the following parts. For free which leads me to believe this is a defect since my dryer is 5 years old and out of warranty.
Parts #
154166 Sensor
436435 PC board
422221 Sensor
Machine is running perfect now. Like I said I think this has been a defect that they just are not doing a recall.
When I keep the grill in front of the filter clean there is no problem with the machine. It is a design issue and would require the entire internal guts to be redesigned and installed.
[QUOTE=ReneQ;702512]When I keep the grill in front of the filter clean there is no problem with the machine. It is a design issue and would require the entire internal guts to be redesigned and installed.[/QUOTE]
I don’t think so. Mine just had issues regardless of how clean the lint screen was. Now with the replaced parts it works great and I love my dryer again.
