Bosch drain pump removal
Dishwasher stopped draining. I checked drain lines & garbage disposal for stoppages. Happened over holidays. I have a feeling the pump is clogged. I disconnected and removed the dishwasher from the cabinet. Do I have to turn it upside down and remove the bottom plastic housing to get at the pump? Can you send me an instruction sheet on how to remove the pump? Thanks, Glenn
Hello,
You don’t need to pull the unit out, you can clean the drain pump with the unit installed. Here is a video that explains how to do so.
Bosch DW Repair Video
