My parents have a Bosh dishwasher in a home they just purchased that won’t quit beeping every so many minutes after the dishes are clean. Is there a way to shut the alarm off? i’m assuming there has to be, but I can’t figure it out.
When cycle is done it beeps to let you know about it. As long as the “on-off” switch is in “off” position there is no power to the dishwasher controls.
They tried to turn the power off, but as you said there is no power to the controls so the dishwasher cannot be run. We’re, therefore, concluding that there is no way to stop the beeping at the end of the cycle. The problem is they like to run the dishwasher and then go to bed. They don’t want to wake up, get out of bed and turn the “Beeping” off. they just don’t want it to beep in the first place.
Thanks for the help anyhow. Please correct me if we’re wrong!
[COLOR=#333333]Hey Gene,[/COLOR]
[COLOR=#333333] [/COLOR]
[COLOR=#333333]Thanks for getting back to me.[/COLOR]
[COLOR=#333333]The test was run as described in the Bosch trouble shooting manual.[/COLOR]
[COLOR=#333333]I did not test continuity of the on/off or micro switches.[/COLOR]
[COLOR=#333333]Is there a pdf on running those tests?[/COLOR]
[COLOR=#333333]Will.[/COLOR]
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
