Bosch Diswasher
Brand: Bosch Dishwasher
Model Number:SHX3AR75UC/15
Main Symptom: It start running, and it stops at a stage were eater comes in from the side and then pumped out this stays for really good time without change. Even when I open the door it still pure water t
Error Code (if any): I can’t identify the error since there is no digital screen
Hi, based on what you’re describing, it sounds like your Bosch dishwasher may be stuck in flood protection mode, which is commonly associated with an E15 error. Since your model doesn’t have a digital display, you may not actually see an error code.
What happens is that water collects in the bottom base pan underneath the dishwasher, causing a small Styrofoam float to rise and activate the drain pump. This would explain why the dishwasher keeps draining instead of starting a normal wash cycle.
Here’s what I recommend trying first:
  1. Turn off the power to the dishwasher at the breaker and shut off the water supply.
  2. If possible, carefully pull the dishwasher out and tilt it about 40–45 degrees, with towels underneath to catch any water. Be careful not to strain the hoses or wiring.
  3. If water comes out, that’s a good indication the flood protection switch was activated.
  4. Set the dishwasher upright, make sure the base is dry, then restore the water and power and try another cycle.
If the dishwasher starts working again, we still need to figure out why water got into the base pan. Common causes include a leaking water inlet valve, excessive soap suds, or a leaking hose or seal.
If no water comes out and the dishwasher continues draining, we may need to inspect the float switch and its wiring. A water-level or flow-sensing problem is another possibility, but it doesn’t necessarily mean the flood switch has activated.https://youtu.be/h1Ye0uoYs78?si=1_p4gkWVXHjSm2Ev
I’ve also attached a video to give you a general idea of where the float switch is located and how to inspect it.
