Bosch Dishwasher
Brand: Bosch
Model Number: SHE68T55UC/03
Main Symptom: No Power
The dishwasher makes a clicking noise but will not turn On.
In the past 3 weeks, it has tripped the breaker during its drain cycle.
I replaced the drain pump. It worked 3-4 cycles. Then gave me E09 code.
I replaced the 00753351 Circulation Motor with heater.
It turned on but errored at E01.
I attempted to clear that with the troubleshooting here. Double checked the connections on the new parts. Everything seems tight and clean.
Now it will not on at all, no lights. It seems to be clicking intermittently.
What now?
I replaced the main control board and have power now.
The user interface is making a weak beep sound. Initially it was accompanied by a flash of “add salt/ add rinse aid”
I am super close to taking all my new parts off and replacing the machine completely.
Any last ideas for me?
With the power supply to the dishwasher turned off, the front door panel can be removed and the user interface secured to the inner panel as much as possible. With the interface secure, the power supply can be turned back on for testing purposes. The attached image is how the wires are routed from the main control to the interface. At the user interface, test from the red wire at pin 4 to the red wire at pin 6 of connection X1. Is there 13.5 Volts DC when the on/off button is pressed?
