BOsch dishwasher
Problem Number one: When I enter the model number SHX43C05UC/43, I can not find a match.
Problem Number Two: I installed the dishwasher and I can not get it to run through the cycles. Water will enter the tub and I can get it to drain but I can not get it to wash. I have read where the control board has failed on the heater cylce on previous models. Can this be the problem with the SHX43 model?
Remove the forward slash and the numbers that follow it. You only need to enter the numbers that are in front of the forward slash
