The dishwasher was started on normal cycle. It filled with water, dropped soap and stopped before completing wash cycle. Rotating the timer knob manually does not engage pumps.
I opened front panel and verified power into the switch block. I did a resistance test on the door safety switch and it seems OK. There is a neon light on the switch block that has turned black with age and the ON/OFF switch does not always “latch” when pushed. Juggling the ON/OFF switch with the door closed does not seem to run the timer motor.
I don’t see any fuses to replace and all the wires seem physically OK as far as I can see. So my guess is that the switch assembly and/or timer is bad. Should I replace both of these parts?
