My Bosch SHE56C05US dishwasher has run perfectly for 7 years, then last night in the middle of the first rinse cycle, when the washer was full of water, it started making a clunking noise. The front panel lights flick on/off, in sync to a click noise from a relay or breaker on the circuit board and a clunk from the base of the washer. It looks like power is being cycled on/off continuously.
It does not respond to the front panel service program, or any other buttons. I checked the drain impeller and it turns freely.
I measured motor resistance the and the main motor is in spec (7.7 ohms & 9 ohms), but the drain motor reads high at 25 ohms. Spec is 15-18 ohms.
Does anyone have any suggestions on what the problem could be?
