Bosch Dishwasher stopped draining
Yesterday my Bosch Dishwasher SHE55M05UC /50 stopped draining. Seemed to make an unusual noise on and off for a few days leading up to the problem.
Looking for suggestions on how to diagnose the problem - any tests I can run?
You will want to test for power coming to the drain pump assembly. If there is power there, and the pump does not run, you will need to replace the drain pump. Make sure the pump is not clogged with debris, and the hose is clear on the unit. There is a attachment on the bottom to help you with the drain pump installation. You can test this with a multi-meter [AP3873826]. Here is a link on how to use a multi-meter. Hope this helps. http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4810-how-check-continuity-ohmmeter.html
AP3996662
Drain pump removal.pdf (349.9 KB)
Jeff,
I tried to remove the pump - removed the toe kick but still not clear how to access the pump.
In the instructions I attached to the last post, it tells you how to remove the pump and shows you a picture of the pump. Once you access the pump, you will remove the wires from the pump and release the locking tab and turn the pump to remove it. Hope this helps.
Thanks I got it, needed to remove door panel and galvanized panel behind toe kick to access the pump
Great Job!! Glad we could help!!
