It doesn’t open during the cycle, and it’s pretty hard to open it manually.
Nothing happens when I push the dark grey button. Also, I’m supposed to be able to use a toothpick and press a light grey lever sideways–nothing happens then, either. The only way to open the tray is to lift the tray front slightly and pull the tray back. I did take the lid off and check for gunk–the tray and the slots were quite clean.
The old thread is for a different model with a different kind of detergent dispenser.
There’s a U-tube video showing how to pop the cover off and clean the dispenser–and that’s the same kind I have. However, it shows how to move the one lever–it’s supposed to trigger the door to open–and for the life of me, I can’t find any part inside the door that the lever should contact.
One thing I do notice. There’s a parts diagram here: at c(dot) Sears Parts Direct (dot)com(slash)lis_png(slash)PLDM(slash)50044418-00002(dot)png (remove spaces and replace items in parentheses)
and I notice that the spring for the door on my machine is shaped differently from the spring shown for part #234 in the diagram. In the diagram, the two ends of the spring are roughly 0 degrees, and mine is closer to 90 degrees, perhaps a bit more. (I wish the diagram would show the opposite view of the one piece in the diagram that does not have an individual part number–I could then possibly draw arrows to the things I’ve referred to.)
I’ve seen options to order a new lid and spring only, or the entire assembly. I’m pretty handy at putting things like this together, especially if I have clear directions, but it sure would be nice to figure out in advance if I only need the spring, or if I’d need the entire assembly.
