Bosch Dishwasher SHXM63W55N/10 E25
Brand: Bosch
Model Number: SHXM63W55N/10
Main Symptom: E25 Error code
What happens & when: E25 code after filling, doesn’t drain
Error Code (if any): E25
Parts or tests already tried: New drain pump, checked drain lines, replaced water inlet valve (some orange buildup from well water), cleaned water matrix, cleaned and inspected check valve, replaced operating module. Pump cover is firmly seated. Can hear whirr of the drain pump starting and attempting drain and then the beep with E25 goes off.
Make sure that if the unit is hooked up to a disposal that the knock out has been removed if it is a new disposal. Also, check to make sure that the disposal port is not clogged. Check the wiring to make sure that there is no damage to it.
No disposal and all wiring looks perfect. Is it possible it’s the power control module? I feel like we have troubleshooted everything we can think of and replaced parts. Trying to figure out when to throw in the towel but still would rather fix for a couple hundred bucks than buy a new quality dishwasher.
At this point the control module would be the most likely cause for this issue with everything else being good.
