All thank you in advance for your help.
I have a Bosch Dishwasher Model # SHX68TL5UC/02 that was working fine, the next time we tried to use it upon opening the door there was no indication of power on the display. This dishwasher has the hidden controls that only require a light touch. The control panel is clean and dry and so are our hands.
I removed the machine from the cabinets and tested for voltage, of which I have 120v through the power cord to the main control board. Using a voltage sensing stick I have voltage through the main board and to the control board in the door. There is no evidence of board damage on either. The door latch switch is not a micro or mechanical switch but a sensing switch which can’t be checked with an ohm meter. All of the wiring is damage free, even at the door hinge point.
If anyone has any other troubleshooting ideas as to what the problem might be.
Thanks for your help.
