Bosch Dishwasher running through several cycles
When I run my dishwasher on regular cycle the timer would start at 94 minutes. Starting yesterday when I ran the dishwasher on regular cycle it would start on 76 minutes, run through that and start a 17 minute cyle and then start a 31 minute cycle. On that last cycle it would get to 1 minute left and continue to run. During that first cycle I checked the water temp about 30 minutes in and the water was barely even hot. Any advice would be greatly appreciated.
i kept the dishwasher running and check the water temp again and this time it did get pretty hot about 30 minutes into the cycle.
My Bosch started misbehaving in a similar fashion about 3-4 weeks ago. At first I noticed it wasn’t drying properly. This occurred for about two days. Then it just never finished washing. It would count down to 1 and run for over an hour without finishing. On occassion, it would start at 102 or similar, work down to 58, then suddenly have 73 on the time or 45 or 23 and then back up again. The cycle chosen doesn’t seem to matter.
I was ready to order repair when I checked my hot water temperature only to find my hot water heater was failing to heat to 120. Have adjusted that, hoping that would solve the issue, but alas it does not.
I am now looking for a way to repair … what I am not sure … but think it may be the temperature sensor without calling out the repairman. He requires $130 before setting foot in the door.
Model # SHE44C06UC/22 purchased Feb 2006.
Ideas are appreciated.
Against the run of play in the opening quarter, Nigeria’s Chidi Odiah made a determined run down the right flank and squared the ball which Uche tapped in after holding off a feeble defensive effort by Cha Du-Ri.South Korea took the lead after Park Chu-Young curled a free-kick around the wall and Kansas City Chiefs Cheap nfl jerseys past Enyeama into far side of the goal.The left-hander surrendered an RBI single to Todd Helton in the fifth inning before the Rockies (37-33) scored again in the eighth when Ryan Spilborghs added an RBI single.South Korea will face Uruguay for a quarter-final spot while Argentina, nfl jerseyswho saw off Greece 2-0 in their final group game, will tackle nfl jerseys Mexico.“When we were ahead we continued to battle and we equalised. But it wasn’t good enough.”
[quote=molson2043;279863]My Bosch started misbehaving in a similar fashion about 3-4 weeks ago. At first I noticed it wasn’t drying properly. This occurred for about two days. Then it just never finished washing. It would count down to 1 and run for over an hour without finishing. On occassion, it would start at 102 or similar, work down to 58, then suddenly have 73 on the time or 45 or 23 and then back up again. The cycle chosen doesn’t seem to matter.
Ideas are appreciated.[/quote]
i ended up replacing the control module and that fixed everything. took about 30mins to replace so its something you can do yourself.
for the reply, Buddylee. I think that may be what I wind up doing. I’ve found the part, it’s backordered at the moment, but replacement looks relatively simple.
While I was looking into this I came across another repair help website that you may want to know about, if you don’t already:
http://www.fixya.com/support/t5936501-bosch_dishwasher_model_she44c02uc_goes
The helper person really seems to know his stuff and is very helpful with photos even! I am going to take a look for the solder joint issue he describes first, before I order, but I will probably wind up with a new control unit.
I thought this www.fixya.com was one of the best sites I’d found.
Good luck to you.
