Rinse aid door will not stay shut. I need to replace with a new one.
How hard is it to replace?
The rinse aid door simply pops out with a little twist from a screwdriver near the hinge. The new one will pop right in very easily. The correct lid for your model is available below.
Bosch 00166623 Rinse Aid Door (with Gasket) - AppliancePartsPros.com
[quote=Appliance Ninja;837342]The rinse aid door simply pops out with a little twist from a screwdriver near the hinge. The new one will pop right in very easily. The correct lid for your model is available below.
Bosch 00166623 Rinse Aid Door (with Gasket) - AppliancePartsPros.com[/quote]
Thank you, “Appliance Ninja”…you rock!!!
You are very welcome, have a great weekend!
You too. Party like it’s 2013 !!
