Bosch dishwasher problem
Brand:Bosch
Model Number:SHPM65Z55N/01
Main Symptom:Stops running
What happens & when: Random
Error Code (if any):None
Parts or tests already tried:None
Multiple problems. Does not start with start button on the first try all the time. Will continue to run with timer at one minute. Does not stop. Water cold. Runs with hot water but stops running after about 5 minutes. Push start button again runs another 5 minutes and stops. Hold start button to reset and it will drain. It does three short drain pulses and then a long one to finish. This sequence happened together in this order. What should I do? I did clean drain filter. Didn’t see a lot in filter.
This issue would be a water heating issue and would want to replace the control board. It will most likely have an issue with a solder joint breaking on the board.
https://www.appliancepartspros.com/bosch-power-module-programmed-12028528-ap6976577.html
Thank you. I will order one.
Is there a video on how to do this? Do i have take the dishwasher out?
Here is a video link for replacing the board.
Thank you very much!
I installed the module. When I first plugged the dishwasher in, all the buttons lit up. I held the resume button and it cleared. Started to wash dishes and heard two soft clicks then E20 error displayed. What should I do? What is the problem? Thank you.
Hello? What should I do? See above.
The E20 Error code is showing as a circulation pump error. The board is not seeing that the circulation pump is working. Test to see if there is power to the circulation pump and if there is but the pump is not running then the pump would be the issue.
