I have a bosch dishwasher that is not draining after doing its dry cycle
anybody have any advice thanks
The dishwasher should drain last time before drying.
The model number you posted is incorrect. Verify and repost it.
Hello,
The first thing I would check is the drain hose, make sure there is a high rise loop, if so go on to the next. Inspect the filter and then the drain motor.
Here is a link to a video that explains how to clean the filter through the inside.
