Bosch dishwasher not draining after cycle (more than usual)
I have a 2 yo Bosch dishwasher that is leaving more water than usual in the base. Filters clean. Nothing has changed or moved since it was running normally before.
Does it run longer than usual? Does it complete the wash cycle? Can you do a Cancel/Drain sequence to stop the wasch cycle. Will this drain it completely?
