Brand:Bosch
Model Number: SHV863WD3N/10
Main Symptom: No
What happens & when: no power on control panel the power cord box I check and it’s getting power there
Brand:Bosch
Main Symptom: No
Hi, since you have power at the junction box but the control panel is still completely dead, the next step is to see whether that power is actually making it through the cord to the dishwasher.
If you have a multimeter and are comfortable working around live electricity, you can check it this way:
Turn the breaker OFF first and pull the dishwasher out far enough to access the power-cord connection.
Inspect the cord and connector for anything loose, melted, burnt, or damaged. Make sure the plug is fully seated.
For the voltage test, set your multimeter to AC volts (VAC) on a range capable of reading at least 120V.
Restore power at the breaker. Do not disconnect or move wiring while the circuit is energized.
At an accessible, insulated test point on the dishwasher’s incoming power connection, carefully place one meter probe on hot (black) and the other on neutral (white). You should read approximately 120V AC.
You can also check hot (black) to ground (green/bare), which should be approximately 120V. Neutral to ground should normally be close to 0V.
Once you have your readings, turn the breaker OFF again before touching, unplugging, or reconnecting anything.
If you have about 120V at the junction box but no 120V at the dishwasher end of the cord, the cord or its connection is the problem. If you have a solid 120V reaching the dishwasher but the machine is still completely dead, then we need to move on to checking the main control/power module and wiring harness.
If you’re not comfortable testing live 120V, don’t attempt this test. An appliance technician or electrician can safely verify the incoming voltage for you.
