Brand: Bosch
Model Number:SHP65T55UC/02
Main Symptom: no lights
All my problems started with a crack in the sump pump. Replaced that got it all back together. Ran a cycle no leak but bottom spray arm wouldn’t spin.
Plug came out on the circulation pump,plugged it back in turn the breaker back on and now the control panel doesn’t light up. It beeps and makes noise but can’t make any wash selection or push start.
I checked all the plugs everything is plugged in but no lights no start
