Brand: Bosch
Model Number: SHP65T55UC/09
Main Symptom: does not turn on
I have no lights or function of dishwasher.
- Pressed Reset
- Checked power at electrical box and at connector on back of dishwasher - there is power (120V)
- Replaced control Board
- Replaced on/off
Still does not work, no lights on front panel
I saw a post about a latch microprocessor? I do not see this
What else can it be?
On the power module you should have 120VAC coming in on L to N. then check for power at connector 8 pins #3 to #6… You should have 120VAC thru the EMI filter on the same power module board. This is the board located at the bottom right side of the DW base.
https://www.appliancepartspros.com/repair-help/dishwasher-repair-help
Is that power board replaceable? The area there is wet from a sink leak. How do I get the module out w/o breaking the plastic tabs so I can test at the board and connector level.
