Brand: Bosch Dishwasher
Model Number: SHX46B02UC
Main Symptom: Unit stuck in “pump out” mode
What happens & when: When the start button is pushed in on all settings, it just pumps slowly accumulating water in sump out into disposal…It doesn’t shut off or allow unit to start cycle.
Based on your description, the dishwasher believes it needs to drain before it can start a wash cycle. Since it never exits drain mode, one of a few things is likely keeping the control from advancing.
Most Likely Causes (in order)
1. Stuck Flood Float or Water in the Base Pan (Most Common)
If water has leaked into the base of the dishwasher, the anti-flood float switch is activated. When this happens, the dishwasher will continuously run the drain pump and will not start a wash cycle.
Test:
- Turn off power to the dishwasher.
- Remove the toe kick panel.
- Look underneath with a flashlight.
- Check for water in the base pan.
If you find water:
- Soak it up with towels or a wet/dry vacuum.
- Restore power and see if the dishwasher starts normally.
- If it does, you’ll need to find and repair the source of the leak.
2. Stuck Float Switch
The float switch tells the control whether the dishwasher is full of water.
Test:
- Open the door.
- Locate the plastic float in the bottom of the tub.
- Lift it up and let it drop.
It should move freely and make a noticeable click from the switch underneath.
If it’s stuck by debris or soap buildup, clean it and try again.
3. Drain Pump Running Because the Drain Relay Is Stuck
If there is no water in the base pan and the float switch operates normally, determine whether the drain pump is actually being powered continuously.
Live Power Warning
These tests require measuring live 120 VAC. Use extreme caution to avoid electric shock. If you’re not comfortable working around live voltage, skip this test.
Start a cycle and measure for approximately 120 VAC at the drain pump.
- 120 VAC present continuously: The control board is commanding the drain pump on. This can be caused by a failed control board or an input (such as the flood switch) telling the control to keep draining.
- No 120 VAC present but the pump still runs: Recheck the wiring. If voltage is absent, the pump should not be operating.
4. Clogged or Restricted Drain System
A partially restricted drain hose or air gap usually won’t cause continuous drain operation, but it’s worth checking.
Inspect:
- Drain hose for kinks
- Air gap (if equipped)
- Garbage disposal inlet (if recently installed, verify the knockout plug was removed)
Reset the Control
Sometimes the control simply needs to be reset.
- Turn the dishwasher off.
- Turn off the breaker (or unplug it) for 5 minutes.
- Restore power.
- Try starting a normal cycle.
A Few Questions
- Do you hear the drain pump running immediately when you close the door, even before pressing Start?
- Is there any water underneath the dishwasher in the base pan?
- Has the dishwasher leaked recently or overflowed?
- Does the drain pump sound like it’s running at full speed, or is it just a low humming noise?
Those answers will quickly narrow it down to either the flood protection system, a float switch issue, or a control board problem.
