Bosch dishwasher heater assembly replacement
Tried a search and didn’t find anything relevant. I am replacing the heater assembly (Part Number: AP2802366 made by BOSCH) on this Bosch dishwasher, as the old one is no longer heating the water. Is anyone aware of any instructions on how to change out this part?
Thanks, Tim
Hello,
I’ve never had to install a heater, but from what I understand it’s not an easy job. Some people I’ve talked to have taken the screws out from the right front and right rear corners and sseparated the tank far enough to get their hands in there, while others have completely removed the base (as shown in the attachment).
KC
SHU_Service_Heater.pdf (304.1 KB)
Your advice and information was great. You were right, it was quite a task. But with the information you provided I was able to get to the heater assembly and change the part. (added complication was figuring out after taking the whole thing apart that the new part I was sent had a crack in the casing. Luckily I was able to swap all of the electrical components over to the old plastic casing and create a good heating assembly).
Only problem is, the water is still not heating. When I ran the diagnostic I got an error code 2 - heating fault. The manual says it could be a “heater, high limit or flow switch” problem. I only understand the heater part of that statement, so I switched the heater.
Any idea what is meant by high limit or flow switch problem? Or could it be something in the control panel?
Thanks again, Tim
Well, if the heater wasn’t the problem it’s probably in the relay board. The way you check the board is, with the door panel removed, put it back into the test mode and when the circulation pump starts to run you should find 120vac between the only solid red wire coming off the bottom of the board and chassis ground. (I usually stick the other lead into the hole you’ll find on the hinge.) If you never see 120v on that wire it’s the board.
Now, here’s the silver lining. It’s sounds like you’re pretty handy, so if you would like to determine what’s wrong with the board you can take the entire board housing out from behind the fascia panel, remove the circuit board and check for a burnt spot dead center on the back on the circuit board. So, if the board is the problem and you find this “cold solder joint” you can just put a dab of solder on it and get your unit working again.
And if you have no voltage and don’t see that cold solder joint you’ll need to replace the board.
Good luck and happy holidays.
KC
Yessss. No current from the red wire, looked behind the panel and just like you said, there was a burned out connection in the center. One drop of solder, and we are in business. Ran the diagnostic, no issues. Nice and hot for the first time in forever.
Thank you for your help. Saved me a lot of money and always more satisfying to fix things oneself.
Have a great holiday season.
Cool - Good Job. It’s always a pleasure to help.
I have similar problems and would like to run the Test programm on my Dishwasher. Do i have to ru the test program with Water Connected or will it test the component in a Dry run mode?
The unit has to be filled with water before the unit will circulate and heat the water. You can fill the unit by hand if you like. A proper water level is when the water is just touching the round, plastic filter handle. If your drain is not hooked up, be aware that the unit will run the drain for about 45 seconds during the first part of the test. This being the case, you should start the test and when the drain stops, open the door, add the water and let it continue the test. Then, when the test is finished, it will drain again.
We are having a challenge getting our Bosch dishwasher fixed. We have a heater assembly part, but cannot figure out how to get to any of the insides to do the replacement.
Your PDF is helpful, but it looks like we could also use pages 3,4,5 to figure out how to remove the door. Can you help?
Our actual product number is SHU5315UC / U12.
Will greatly appreciate any help you can provide. We live in the mountains and none of the Bosch authorized servicers will come here.
Hello,
The door doesn’t have to be removed in order to get to the heater, but if you would like to know it’s as simple as removing the bottom three screws from each side of the inner door. These are the T-20 screws you see when you open the door and look at the edges of the stainless inner door panel.
KC
I have a Bosch dishwasher, model: SHE45M06UC/48.
The water is not being heated, and a technician diagnosed the problem as a faulty heater assembly (voltage to heater present, but no current draw). Given the quoted repair price (> $500), I have decided to replace the assembly myself.
I have two questions:
  1. is the above posted file, SHU_Service_Heater.pdf, the right file for this unit, or do I need a different document?
  2. I’d like to confirm the diagnosis vs. the exhibited behavior:
    The unit runs a full cycle, but the water is not heated (tap water temp).
    Before the unit failed, there was a quiet period during the early part of the cycle while the water was being heated. Now there is no quiet period - the unit starts spraying water right after filling. Is this consistent with a faulty heater assembly or is there something else that might be wrong?
Thanks much!
Any chance on getting the other pages to this???
Is it possable to get pages 1 thur 12 on that SHU_Service Heater PDF?
Thanks!!:slight_smile:
[QUOTE=Donn Snyder;317938]Is it possable to get pages 1 thur 12 on that SHU_Service Heater PDF?
Thanks!!:)[/QUOTE]
Hi, would appreciate all pages also if possible.
