Bosch - Dishwasher - Error: E:61-03
Brand: Bosch
Model Number: SHX9PCM5N/22
Main Symptom: Error Code: E:61-03
What happens & when: Dishwasher will start and run for a period of time just fine. It then stops and displays error E:61-03. Online documentation is conflicting—some sources say it’s a drainage issue, others say it’s a water-heating fault.
I’ve already tried these troubleshooting steps:
  1. Checked the drain hose for clogs.
  2. Looked for any air pockets that would prevent draining.
  3. Cleaned the filter and check any blockages.
  4. Removed the drain pump guard and cleared a small amount of debris behind it; the drain pump spun freely when I reinstalled the guard.
  5. Opened the machine immediately after the error; it was in a hot-water cycle and the water was getting hot but the cycle hadn’t run long enough to reach full temperature
Thank you Pro App Team for all your assistance!
https://www.bosch-home.com/us/owner-support/error-codes/dishwashers#/Togglebox=16535672-16716986-41/
Also watch this video:https://mycliplister.com/play/81514/16245959c8d47b130f21e454bbfeb01b1d243823d9e355a8aeeb4922a025083ee_x3ebd6aa42a7724bc3cabc9d9b532d28c0098e73e278de3f9fbd23c43d6e5434e?width=640&height=360
HI Big Buck,
Thank you for your feedback and assistances. I did find that Bosch website as part of my troubleshooting steps. Also thank you for sending the video clip. I saw a youtube video that was similar, recommending that same procedure. That was part my 1-4 troubleshooting steps. Bosch is focusing that its an evacuation pump issue and other website sites are saying its a water-heating fault issue.
Hey Appliance Part Team,
Do you have any feedback on this. Still having a problem and haven’t been able to find the issue. Would like to get a part of fix this if you had any suggestions.
