My Bosch Axxiss washer stopped spinning. I ran the diagnostic test and determined the motor was not working. After removing the motor I noticed that one of the six blue wires in the small connector plug for the motor had broken off. It seems there is no easy way to take apart the connector to reconnect the wire. Is that true? Should I try and apply a small amount of solder to reconnect it, or is there some trick to mechanically reconnecting the wire?
Richard
Hey all. Having the exact same problem on our Bosch Axxis washer. Be replaced the brushes about a month ago and just the other day it’s drum stopped spinning again. When pulling the motor out to check the brushes again one of the wires in the six wire harness connector pulled out very easily. It doesn’t look like there’s any easy way to replace the separated wire. Anyone got any ideas? We would really rather not pay for a new $60 wiring harness. Thanks in advance!!
-Steve
-Steve
