Bosch Axxis condenser dryer leaks
My new Bosch Axxis condenser dryer was just installed and it leaks water instead of putting it out through the drain hose that is attached to the drain. What could be causing this?:confused:
Might have a plugged drain line.
This video will help fix the drain line:
https://youtu.be/QUK9pALRL-g
