Brand: Bosch
Model Number:SHXM78W55N/01
Main Symptom: water tap error on display and beeping
What happens & when: a few minutes after starting the cycle, the dishwasher starts beeping and the water tap error illuminates. I can watch the clear fill tank fill as the inlet valve cycles, but it doesn’t seem to be circulating well in the dishwasher itself when running.
Error Code (if any): water tap error (no number, just a word on the display that says water tap)
Parts or tests already tried: I have watched the tank fill and drain through a cycle. I removed the inlet hose and checked the screen, it had some crud but I know that was from before my whole home filter which has been a few years now.
