Bosch 300 Dishwasher - Aborting mid-cycle (Rinse - Approx 45%)
Brand: Bosch
Model Number: SHS43CF5N
Main Symptom: Stops Mid-cycle (app says Aborted)
What happens & when: It’s as if you turned it off and back on after it drains, refills and in a few minutes into the final rinse.
Error Code (if any): Can’t get the codes to read out on the leds.
Parts or tests already tried: Main board swapped, water sensor replaced, door removed/dismantled and all wires checked.
Seems VERY consistent and test was done in the 60-minute wash. If it helps, the 60-minute wash routinely shows nearly 1 hour and 30 minutes opposed to the 60 minutes. Any help would be Greatly appreciated. I’ve been pushed (by AI) to change the door board but I’m not seeing the justification as it’s so specific when it times out. It heats and pumps without issue. Please ask any questions you might have and I’d be so very thankful to get this behind me and the wife quieter about it. LoL
If you run the 60-minute cycle, does the dishwasher still cut out just after reaching the final rinse phase? With the dishwasher in standby (no LEDs illuminate) press and hold the Speed 60 and the Favorite buttons. While holding the buttons, press the power button. Release the Speed 60 and the Favorite buttons to enter into the special functions menu for this dishwasher. The Favorite LED should illuminate solid and the Remote Start LED should flash. Press the Remote Start button. If there is an error code, it should display at this point. Let me know what you find and we can go from there.
