Boot wire/spring replacement
I managed to stretch the wire/spring assembly that wraps around the rubber boot on the door, so need to replace it. In the meantime, is it safe to run the washer without the wire/spring on the boot? No desire to clean up a big, wet mess.
Here is the part.
[COLOR=#0000ff][COLOR=#0000ff]AP4044526[/COLOR][/COLOR]
I would not operate the machine without this as water may leak onto electric parts and cause all sorts of problems.
