blinking lights are soak and scour, drying, off,4,6hr .Changed control board no change.Does anyone have any idea what could be causing this?
Parts for Whirlpool DU1055XTVT1 Dishwasher - AppliancePartsPros.com
Could be a control panel (keypad) problem.
Since there are a number of lights blinking that do not have a key it sounds like a problem with the circuit paths for the LED’s.
Unfortunately they do not show these in the tech sheet.
I would still check the keypad with a meter just to see if something comes up bad.
DU1055.pdf (244.3 KB)
