the Pots&Pans light and the Normal Wash light are blinking along with the power scour light.. i mess with the buttons an then the powerscour light is blinking by itself, sometimes with 4H in the status/time remaining
any help will be greatly appreciated.
Most likely the problem is a bad key pad which is a part of the control panel. If you need the correct part number, post the color of the control panel.
